oulyve
Sep 29, 2025Aspirant
How to connect my RBR850 to my KPN network (NL)?
Dear community, I am located in The Netherlands. I was so far an happy owner of an RBR850 mesh system ( 1 main device and 2 satallites) for more than 3 years. My internet provider was ODIDO but I ...
Sep 30, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
