drakov's avatar
drakov
How to disable SSID broadcast on RBR750, Firmware Version V4.6.5.14_2.0.54
Hi, I cannot see the disable broadcast SSID on the config page. Anyone know where I can go to disable the SSID on this device?
1 Reply
  • You can't disable the SSID of the main wifi in RBR750. You can only disable the Guest Wifi SSID.
