gene_s
Apr 04, 2023Follower
How to make CBR750 compatible with sonos
My Orbi CBR750 does not recognize my sonos system. THe sonos folks say that I have to change the 802.11band to b/g/n. How do I do that. Is there any other tips on how to get Orbi to recognize sonos...
Apr 04, 2023Guru - Experienced User
power off the other satellites and try connecting the sonos device directly to the CBR750 and not the satellites. Once its sync'd, then try the satellites.
