gene_s
Apr 04, 2023Follower
How to make CBR750 compatible with sonos
My Orbi CBR750 does not recognize my sonos system. THe sonos folks say that I have to change the 802.11band to b/g/n. How do I do that. Is there any other tips on how to get Orbi to recognize sonos...
KevinLiT
Apr 04, 2023NETGEAR Moderator
Hello gene_s ,
Welcome to the NETGEAR Community!
I understand that your Sonos device needs the Wi-Fi band that is IEEE 802.11b/g/n to sync to the network. The CBR750 is compatible with the wireless standards IEEE 802.11b/g/n/ax. The issue here is that the Sonos wireless speakers are not able to find the 2.4GHz network needed to connect to your network. Please try connecting your Sonos speaker to your guest network to establish a connection wireless connection.
Community Users with this issue have been able to resolve this issue by giving their wireless hotspot the login credentials of their main network and then connecting their IoT devices. After the connection has been established they are able to connect their IoT devices to their main Orbi network.
Best,
Kevin
Community Team
