Telliott47
Aug 12, 2025Aspirant
HP Officejet Pro 8620 Cannot Connect to Internet
I have a HP Officejet Pro 8620 printer. I also have an Orbi - AX 6000 Router. I am enrolled in HP Instant Ink program which requires my printer to connect to HP servers. I have internet connection...
Aug 12, 2025Guru - Experienced User
Is the printer connected to the main WLAN, IoT network or via Ethernet?
What security modes are being used on the Orbi router? WPA2 only or Mixed Mode WPA2/WPA3?
Something to check with HP support about as well.
Telliott47
Aug 20, 2025Aspirant
Thank you for your response. Firmware version - v7.7.15. Mfr is Netgear / Model AX 6000. The printer is connected to WLAN 2.4 GHZ WiFi. I went into settings and toggled "loT" to the on position. Orbi router security mode is WPA2. I turned on loT because it says it works well for older devices. However; still no luck.
- FURRYe38Aug 25, 2025Guru - Experienced User
You'll need to make contact with the printers Mfrs support for help and support information regarding there product.
