gficker's avatar
gficker
Follower
Dec 09, 2024
https://www.orbilogin.net/
I was send to the adres  https://www.orbilogin.net/
then I have to login
but I don't know to fil in
My login to the netgear site is not the same
  • FURRYe38's avatar
    Try getting to the recovery screen by entering the PW 3 times. Then see if you can get in here.
    If that fails, You'll need to factory reset the system and setup from scratch with a wired PC and web browser.
    What model Orbi do you have?
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello gficker,
    Welcome to the NETGEAR Community!
    I understand that you are unable to log into your Orbi's Administration portal (orbilogin.net) using your passwords or your security questions. Unfortunately, you will need to perform a factory reset your Orbi Mesh system.
    Please navigate to the link below for instructions on how to correctly:
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    Best,
    Kevin
    Community Team
