ketihsplace's avatar
Jun 11, 2024
I am getting "Device Name Has Reached Limit" when trying to name another device RBR850
Is it a number of devices you can name, have or characters in the naming, what is the limit?
I have an RBR850 with 3 Satellites and 31 connected devices.
Just trying to name a second NAS device, it won't let me select or name device type, when I click apply just pops up device limit error "Device Name Has Reached Limit"
  • michaelkenward's avatar
    michaelkenward
    Add how?
    NAS, (network attached storage) usually means a wired device. You don't add it. You just plug it in
    • keithsplaceORBI's avatar
      keithsplaceORBI
      Tutor
      No it’s added, shows up just trying to name in the UI connected devices. All of my devices are showing up, named etc, it’s like this last device will not change to the NAS icon or name the device. Just goes back to geniric device and will not me change the name.
        keithsplaceORBI
        Tutor
        Like is there a limit to how many devices can be named? Or how many characters the naming buffer has?
  • CrimpOn's avatar
    CrimpOn
    Could you please humor me and check the Orbi web administration page on the Advanced Tab called Access Control.
    There are three tables:
    • Devices connected to the system.
    • Allowed devices which are not currently connected..
    • Blocked devices which are not currently connected.
    If the three tables contain an unusually large number of devices, it might be useful to:
    • Enable Access Control (if it is not already enabled)
    • Delete all devices from the Allowed and Blocked tables
    • Return Access Control to the original setting.
    Orbi routers remember every device that has ever connected to the system in case the user should decide to enable Access Control.  If there have been a lot of devices connected over time, or there are a lot of Apple devices which randomize their MAC address every time software is updated, the list of remembered devices might be very large.
    Or...... "I have no clue".
    • ketihsplace's avatar
      ketihsplace
      Tutor
      In Access control
      The device is listed at top as allowed with it's name, ip, mac, and as Wired device.
      There are there are 0 listed in the Allowed devices not currently connected.
      There are there are 0 listed in the Blocked devices not currently connected.
      • CrimpOn's avatar
        CrimpOn
        ketihsplace wrote:
        In Access control
        Thanks for taking the time to look at the Access Control tables.  That would seem to rule out the number of devices as being pertinent to the discussion.  (Although it beggars belief that there can be zero devices that have ever connected to the system and are not connected at this instance.)
        The other obvious possibility is the number of characters in a device name, but I would think you have already tried to change this device to a very short name consisting of only alphabetic characters, correct?
        p.s. on an RBR750, I find that the maximum length of a device name is 32 characters.  Anything entered after that simply disappears.
    michaelkenward
    ketihsplace wrote:
    Just trying to name a second NAS device...
    Use a web browser to access the graphical user interface (GUI).
    • Basic
    • Attached Devices
    • Connected Devices
    • Click "second device"
    • Edit Device
    • Change "Device Name"
    • Change "Device Type"
    • Apply
    This works for my MR90. Most routers should have the same approach.
    Apps are for simple management operations. They can't handle complicated stuff.
