Timo40
Sep 22, 2026Aspirant
I am having so many issues with my orbi 6 router and satellites
I am having so many issues with my orbi 6 router and satellites. Constant drop outs lose connection with internet. One minute it’s fine then gone. I’ve tried reboots, reinstalls, turning off iv6, tur...
- Sep 22, 2026
IF your not getting internet at times from the ISP, then could be an ISP issue between them and there modem/router that the RBR is connected too. Red means the RBR isn't getting good signal from the ISP modem. Have them check everything up to there modem.
Cam use there router in router mode and connect the RBR then and see if the RBR still continues to see RED in the app. Use the ISP routers DMZ for the RBR in router mode.
Or try AP mode on the Orbi system with the modem in router mode.
What Firmware version is currently loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
Timo40
Sep 23, 2026Aspirant
Hi, thanks for the reply. I am now using the orbi in router mode as you suggested, so far so good. No dropouts for 24hrs. I have lost the first account option which is a shame but have I lost any performance in terms of speed etc or are the speeds I’m getting from my isp the speeds I would have got anyway with the orbi router? Thanks again, really helpful.
Sep 24, 2026Guru - Experienced User
Timo40 wrote:have I lost any performance in terms of speed etc or are the speeds I’m getting from my isp
What speed are you getting? What speed are you paying for from your ISP?
The Orbi has a speedtest built in, but I suggest also running one from a client (both wired and wireless).
- Timo40Sep 29, 2026Aspirant
Hi, thanks. I’ve wanted up turning the orbi into router mode and haven’t had a single drop out since. I’ll keep it like that for now and see if it happens again. Thanks for all the help and info.
