Retired_Member
Jun 09, 2025I found that disabling all logging and then performing a full power cycle of my 963 system
I found that disabling all logging and then performing a full power cycle of my 963 system—a step I came across in the post linked below (which discusses BE systems)—resulted in a significant perform...
Jun 10, 2025Guru - Experienced User
Only ones I have enabled on my 963 system:
| Include in Log | |
| Connections to the Web-based interface of this Router | |
| Router operation (startup, get time etc) | |
| Known DoS attacks and Port Scans | |
| Wireless access | |
I also have SIP ALG enabled as well. Normally disabled by default. Was mentioned years ago that enabling this helped as well.
- Retired_MemberJun 14, 2025
Thanks will try this when I get round to it.
- donawaltOct 27, 2025Hero - Experienced User
FYI I read SIP ALG (Application Layer Gateway) is a helper service meant for old VoIP systems — it inspects and modifies SIP (Session Initiation Protocol) packets for voice calls.
On many modern routers, SIP ALG causes more harm than good, breaking VoIP calls, Ring doorbells, or Teams/Zoom sessions. Disabled for me, haven't seen any issues.
- FURRYe38Oct 28, 2025Guru - Experienced User
There was a known issue about 15+ years ago with SIP ALG. Also uPnP. I've been using SIP ALG and uPnP since then. Have not seen any issues. Have also asked beta testers to help test SIP ALG in past projects with it enabled or disabled, have had zero problems with it. I would presume and guess that since 15 years have passed that the core devs for SIP ALG and uPnP have make corrections and changes to these features since then, and should not be a problem to use them either way today.
- StephenBOct 28, 2025Guru - Experienced User
donawalt wrote:
SIP ALG (Application Layer Gateway) is a helper service ... On many modern routers
Yes. It is not "modern routers don't need them", it is instead that VOIP providers have built infrastructure for NAT traversal into their clouds.
Another aspect is that the SIP packets can't be modified when the signaling channel is encrypted (TLS in the case of SIP), and the best practice today is to encrypt both the signaling and the media.
So modern VOIP phones (and other SIP clients) generally don't need the router ALG. And it can sometimes get in the way.
donawalt wrote:
Disabled for me
And for me. I think in general people should disable it, unless they discover that they need it.
