Retired_Member
Jun 09, 2025I found that disabling all logging and then performing a full power cycle of my 963 system
I found that disabling all logging and then performing a full power cycle of my 963 system—a step I came across in the post linked below (which discusses BE systems)—resulted in a significant perform...
Retired_Member
Oct 24, 2025Just an update on this, I have found that if you have netgear armor enabled, there then seems to be some issue related to the logging, I have now factory reset and setup from scratch via the via web gui and not used the orbi app, and haven't had to disable any logging.
- FURRYe38Oct 24, 2025Guru - Experienced User
Good ol Armor doing stuff.
Wondering if you used Orbi app and disabled Armor in the app, does problem still continue?
- Retired_MemberOct 26, 2025
Disabling armor doesn't seem to fix the issue, at least for me anyway.
- FURRYe38Oct 26, 2025Guru - Experienced User
So just doing a reset and setup from scratch with out using Orbi app and leaving Armor not enabled and logging enabled, seems have the system working well?
