Jroach
Jul 31, 2025Luminary
I have a similar issue with my RBR850 but I'm on V7.2.6.21
flyingdutchgeek I have a similar issue with my RBR850 but I'm on V7.2.6.21, wired backhaul and every time I look at the satellite its either magenta, white and blue. I disabled the firmware update...
Jroach
I started to update to the latest V7 2.7.15. Update RBS (ok) then wen to update RBR but failed with something like check the file. Downloaded the file again for the RBR (not the RBS), still failed. Tried to roll back the RBS from current to previous but I can't find the specific file for RBS for 6.21.
Jul 31, 2025Guru - Experienced User
What browser are you using? Try MS Edge or Firefox? I always use MS Edge.
I presume you did unpack the .zip files before using.
Did you use the RBS web page to do the FW update?
I always have the RBS web pages open in a tab for each unit, then the RBR as well in a different tab. I'm able to send one RBS at a time, then once I see the progress cicle on both, I then go and send the FW file to the RBR on it's manual tab page there. .CHK file will be sent there. I then wait for all to get processed and come back to ready.
