Jroach
Jul 31, 2025Luminary
I have a similar issue with my RBR850 but I'm on V7.2.6.21
flyingdutchgeek I have a similar issue with my RBR850 but I'm on V7.2.6.21, wired backhaul and every time I look at the satellite its either magenta, white and blue. I disabled the firmware update...
Jul 31, 2025Guru - Experienced User
Could work, however RBR and RBS should be on same FW level. Let it run for now and see how it goes.
Will need to get the RBR updated at some point though.
Something to try to load the RBR using NMRPFlash maybe if Chrome or Firefox don't do it normally.
Jroach
Aug 03, 2025Luminary
USING Chrome, loaded 2.7.15 onto rbr850. Factory reset after. Still having problems and lost Samsung TV's (maybe they are set for IPv6?
In the logs around the same time as the failure I'm seeing: [UPnP set event: AddPortMapping] from source 192.168.1.37, Sunday, Aug 03,2025 15:16:33
That device is a Sonos speaker
I will likely try and roll back to the previous version of firmware.
- FURRYe38Aug 03, 2025Guru - Experienced User
What happens if you disable IPv6 on the RBR?
