Jroach
Jul 31, 2025Luminary
I have a similar issue with my RBR850 but I'm on V7.2.6.21
flyingdutchgeek I have a similar issue with my RBR850 but I'm on V7.2.6.21, wired backhaul and every time I look at the satellite its either magenta, white and blue. I disabled the firmware update...
Jroach
Aug 05, 2025Luminary
FURRYe38 thanks for the advice
Maybe safari or ???? but this forum is difficult to figure out. I'm use to things being in an order of old to new and no matter how I sort it my most recent comments don't appear (at least where I think they should be)...oh well
might have found a 'smoking gun' thanks to your advice about setting the range .100 to .200. Two device kept falling below .100. Turns out those devices had static IP set, likely from some issue a few years back. One of the IP address' was .41 (ref earlier in this thread that that seemed to be a duplicate). Changed them to dynamic and monitoring.
- FURRYe38Aug 05, 2025Guru - Experienced User
Ah ok. So already had one at .41 static. Could have left it there if yo uchanged the range. But see how it goes now. Probably good now.
I use Opera GX for forum postings.
I refresh the pages as well to see new posts or updates.
- JroachAug 05, 2025Luminary
Good to know about Opera GX.
Problem persists. Not enough tools with Netgear/Orbi to see what's going on and I need an appliance, not a hobby:)
I think it's time to move on and try something new. Have you had any experience with the eero 6 or TP-Link Deco BE63? Rich Demuro
recommends both and seems to be a pretty unbiased opinion (I hope)
So both devices are on sa,e .41 IP?
Or is this the RBS front LED issue?
We don't recommend other Mfrs in this forum. Were here to help get users problems fixed with NG systems.
