Jroach
Jul 31, 2025Luminary
I have a similar issue with my RBR850 but I'm on V7.2.6.21
flyingdutchgeek I have a similar issue with my RBR850 but I'm on V7.2.6.21, wired backhaul and every time I look at the satellite its either magenta, white and blue. I disabled the firmware update...
Jroach
Aug 06, 2025Luminary
I'll try the 30-30-30 and report back.
Tks for the tip about other RBS' compatible with the 850 but if the reset you outlined doesn't work then I've gone past my limit time wise. Whats crazy is
this is my third Orbi and if I replace it with another Orbi then I think I lost my marbles. Always the same thing, some error and too difficult to find the root cause but replacing it
works for a few years.
