Jroach
Jul 31, 2025Luminary
I have a similar issue with my RBR850 but I'm on V7.2.6.21
flyingdutchgeek I have a similar issue with my RBR850 but I'm on V7.2.6.21, wired backhaul and every time I look at the satellite its either magenta, white and blue. I disabled the firmware update...
Jroach
Aug 07, 2025Luminary
In that jpg the problem child was the wired RBS. I believe the "out of sync" device was actually an apple airport express or apple TV as it became "Disconnected" when I removed those devices. Has been running without error for several hours. I forgot to turn off the firmware update so it's at the latest and I'll leave that way for a few days so I don't introduce too many changes. Next step is to plug back in some of those devices removed, one at time...maybe an hour or so in-between. I'll report back but none of these devices are new, been attached for as long as I've had the router so I don't know if it was a device or the 30-30-30 reset
Aug 07, 2025Guru - Experienced User
So v.15 loaded on the RBR and RBS?
Do you think one of the apple devices that could be causing problems?
- JroachAug 07, 2025Luminary
Yes, v.15. Yes, that’s what I’m thinking but don’t know why. Apple ax has an extender capability but that should be disabled as it’s just being used to provide streaming to a McIntosh multi room amp
- JroachAug 10, 2025Luminary
its been running for 48hrs now w/o issue. Pretty certain Apple AX was the device causing the issue. I believe that when the new TV was installed the AX cable might have been disconnected/reconnected to the wrong port (LAN vs WAN). I didn't take it any further and since the device is so old I just replaced it with an that has integrated network.
- FURRYe38Aug 10, 2025Guru - Experienced User
Is there a product link to this Apple AX device? Just like to see what this device is.
Glad you figured what the main culprit was and not a FW issue.
