Jroach
Jul 31, 2025Luminary
I have a similar issue with my RBR850 but I'm on V7.2.6.21
flyingdutchgeek I have a similar issue with my RBR850 but I'm on V7.2.6.21, wired backhaul and every time I look at the satellite its either magenta, white and blue. I disabled the firmware update...
Aug 07, 2025Guru - Experienced User
So v.15 loaded on the RBR and RBS?
Do you think one of the apple devices that could be causing problems?
Jroach
Aug 07, 2025Luminary
Yes, v.15. Yes, that’s what I’m thinking but don’t know why. Apple ax has an extender capability but that should be disabled as it’s just being used to provide streaming to a McIntosh multi room amp
- JroachAug 10, 2025Luminary
its been running for 48hrs now w/o issue. Pretty certain Apple AX was the device causing the issue. I believe that when the new TV was installed the AX cable might have been disconnected/reconnected to the wrong port (LAN vs WAN). I didn't take it any further and since the device is so old I just replaced it with an that has integrated network.
- FURRYe38Aug 10, 2025Guru - Experienced User
Is there a product link to this Apple AX device? Just like to see what this device is.
Glad you figured what the main culprit was and not a FW issue.
https://en.m.wikipedia.org/wiki/AirPort_Express
They were a very reliable solution that you could attach to analog audio output for airplay streaming. Combined with Satellite you had on/off, volume an EQ. Might be the first time I touched in 10 years…RIP:)
