V3_
Jun 25, 2022Follower
I just noticed some of my IoT devices were also being disconnected randomly because of my Satellite
Hello,
I just noticed some of my IoT devices were also being disconnected randomly because of my Satellite disabling its 2.4 GHz channel.
I followed your instructions and disabled the 20/40 MHz Coexistence. I'll update in some days whether it worked or not for me too!
Thanks for posting so I could find an answer to my issue 🙏🏻.
PS: I don't know about you guys but my Orbi Satellite is connected under Ethernet Backhaul. I don't remember experiencing such issues back when it was connected to the router via its 2.4 GHz proprietary channel. It might be related?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Is the RBS connected directly being the RBR or is there a LAN switch in between?
What CAT# lan cable are you using? CAT6 is recommended.
Any progress on this?
V3_ wrote:
Hello,
