nthstar's avatar
nthstar
I'm hoping to get some help with this topic as well please
I'm hoping to get some help with this topic as well please.
I have 1 X RBR850 and 1 X RBS850 (connected via ethernet to the RBR) and positioned ~30ft from the RBR unit. Devices are in Router mode.
Firmware on web and app say it's up to date but it's on 4.6.3.16 which I know isn't the latest.
I will have 50 MAC laptops connected to the RBR all day with ~855Mbps TX rate and no dropouts at all. These devices would be 5-20ft away at any time.
But when we're 5ft from the RBS (I also will have ~855Mbps TX rate which makes me confident I am connected to the RBS and not the RBR), the MAC will lose wifi literally every 3-5 minutes (MAC wifi icon turns off and then shows it searching and reconnecting to the Orbit wifi). Looking at the Orbit app (which I don't think is accurate) it also shows minimal devices connected to the RBS and the majority connected to the RBR, but I do believe I am on the RBS.
The RBS is ~30ft from the RBR and I'm wondering if the system doesn't know which device to connect the MACs to hence the dropping?? I also wonder if the satellite is faulty. And I also wonder do I just remove the satellite completely and see if the router can cover the whole space itself. This last option is disappointing as I spent $1200 on the 2 device's for max coverage.
Any ideas you have would be recommended.
I'd like to do a firmware update and see if that fixes things, but I'm worried it'll make things worse especially because I'll have to do the update manually.
  • FURRYe38's avatar
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    Also try turning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    • nthstar's avatar
      nthstar
      - DrayTek Vigor 2865
      - roughly 350sq ft
      - Under the web portal for "wireless settings (general) it says:
      -- Region Australia
      -- 2.4G Channel Auto (2)
      -- 2.4G Wireless mode: Up to 1147 Mbps
      -- 5G Channel 36 + 40 + 44 + 48(P)
      -- 5G Wireless mode: Up to 2402 Mbps
      - I can see 16 when on the Orbi Wifi App (in Wifi Analytics) and 38 other SSIDs when I search for WiFi Networks on my MAC laptop
      - Under "2.4GH" it is a tick box saying "Enable 20/40 MHz Coexistence". Are you saying I should untick this to make it default to 40Mhz?
      - Preamble mode for 2.4 and 5gz are both sent to "Automatic"
      - I cannot just turn the power down for the Router. I have to turn down the Signal for 2.4 or 5Ghz.
      - I've moved both down to 50% to review how that works
      The change I have made is to reduce the 2.4 and 5Ghz signals from 100% to 50%, so I'll see how that goes over the next few days and report back.
      Thanks,
      Andrew
      • FURRYe38's avatar
        What mode is this working in? Router or Modem mode?
        https://www.draytek.com/products/vigor2865/
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        - roughly 350sq ft
        350sq ft? <IF this is right, you don't need any RBS. Only the RBR will be needed. The size of home would be too small for RBS.
        -- Region Australia
        -- 2.4G Channel Auto (2) <Try channels 1, 6 or 11.
        <You maybe in a wifi congested area.
        - Under "2.4GH" it is a tick box saying "Enable 20/40 MHz Coexistence". Are you saying I should untick this to make it default to 40Mhz? <Lets leave this enabled for now.
        - I've moved both down to 50% to review how that works< That what was meant my turning down the transmit power.
