Mastra11
Feb 28, 2026Apprentice
Information on connecting to your new ISP modem/router
Good morning, in the area where I live they've installed pure FTTH fiber optics, so my ISP will be changing my router. I have an Orbi RBK 753 system in router mode connected to the LAN port of my cur...
Feb 28, 2026Guru - Experienced User
Depends on what the ISP router uses for it's IP address, maybe 192.168.1.1 which is default for most NG router systems, however NG router systems and auto adjust for this.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-pointand https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
