Dbsoccer
May 23, 2025Aspirant
Initial Set-up Questions
I just reset my RBR850 router and am now re-setting everything. But like the first time I did this I see all the options to choose from and not the knowledge to pick. For example, under the Basi...
- May 23, 2025
Thanks Kevin! Have a good day.
KevinLiT
May 23, 2025NETGEAR Moderator
Hello Dbsoccer ,
Welcome to the NETGEAR Community!
I understand that you would like more information on the best network configuration for your RBR850. Users found that it is better to use Google DNS than the ISP. Simply tap "Use these DNS Servers" and input 8.8.8.8 as primary and 8.8.4.4 as secondary.
For security purposes it is best practice to use WPA3 encryption. However, this may cause some compatibility issues with some devices. I recommend to use WPA3 encryption unless there are issues with compatibility with attached devices.
Please see attached the user manual for the RBR850 for further assistance:
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
Best,
Kevin
Community Team
- DbsoccerMay 23, 2025Aspirant
