cdsatpb
Jun 27, 2025Aspirant
Initial set up
A very basic question: does the router in an Orbi mesh system connect to the ISP router, or does it replace the ISP router? (I have a Utility Warehouse router which is currently plugged into the fi...
Jun 27, 2025Guru - Experienced User
Could possible do both. Someting you'll need to ask your ISP about as some ISPs may differ on there requirements on what can be connected to there main debarcation terminal for there services to your home.
IF there is a router at the ISP point, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
If you deploy a orbi system then you would want all your devices connected to the orbi system so all devices can get connected on same system and communicate with each other with out interuptions.
cdsatpb
Jul 05, 2025Aspirant
Thank you.
