whitetiger97
Nov 25, 2025Aspirant
Interference with Vehicle Backup Camera
I have anOrbi 750 with 3 satellites around the house. Approx 2500 sq ft house on one acre. Router in one corner, satellite in another corner, satellite in garage (in a triangle configuration) and one...
- Dec 02, 2025
I have tried setting my router away from Channel 11 and it has since made both cameras work properly. I think that Garmin should include that the BC50 is also on Channel 11 of the 2.4 Ghz band.
And they should have known this in all the communications that we had because I mentioned it to them in our correspondence instead of me finding out here.
Thank you to all that responded.I will closing this thread.
whitetiger97
Nov 26, 2025Aspirant
I don't know exactly how it transmits, just know that it is at 2.4 GHz. It is strange that it work fine while I am installing it in the garage right under the one satellite but as soon as I go out in the yard to back up to trailers it starts to buffer and glitch. We live outside a city on 1 acre and there are not very many neighbors. I go down the road 250 ft and it works fine. I come home, unplug the router and it works fine. I have worked very hard over a 7 month period, with the company (Garmin) and they can only state the interference from the mesh system. That is why I came here for suggestions.
