whitetiger97
Nov 25, 2025Aspirant
Interference with Vehicle Backup Camera
I have anOrbi 750 with 3 satellites around the house. Approx 2500 sq ft house on one acre. Router in one corner, satellite in another corner, satellite in garage (in a triangle configuration) and one...
- Dec 02, 2025
I have tried setting my router away from Channel 11 and it has since made both cameras work properly. I think that Garmin should include that the BC50 is also on Channel 11 of the 2.4 Ghz band.
And they should have known this in all the communications that we had because I mentioned it to them in our correspondence instead of me finding out here.
Thank you to all that responded.I will closing this thread.
Nov 26, 2025Guru - Experienced User
whitetiger97 wrote:I don't know exactly how it transmits, just know that it is at 2.4 GHz
Garmin doesn't say, but is certainly isn't Bluetooth.
whitetiger97 wrote:have worked very hard over a 7 month period, with the company (Garmin) and they can only state the interference from the mesh system
No doubt it is interference.
The question is what can you do about it. The information on Garmin's web site doesn't give any guidance.
Looking at the manual for the 750, there does not appear to be any way to lower the signal strength of the mesh elements. So that apparently isn't an option.
There is power adjustments on the RBR750 series system. 100,50 and 25% under Advanced Tab/Advanced Settings/Wireless Settings
- CrimpOnNov 26, 2025Guru - Experienced User
changing Transmit Power affects every unit in the system (router and every satellite).
It would be interesting to see how large an area is affected by this situation.
- StephenBNov 26, 2025Guru - Experienced User
Yes. Though in this case only 2.4 ghz needs to be reduced.
