whitetiger97
Nov 25, 2025Aspirant
Interference with Vehicle Backup Camera
I have anOrbi 750 with 3 satellites around the house. Approx 2500 sq ft house on one acre. Router in one corner, satellite in another corner, satellite in garage (in a triangle configuration) and one...
- Dec 02, 2025
I have tried setting my router away from Channel 11 and it has since made both cameras work properly. I think that Garmin should include that the BC50 is also on Channel 11 of the 2.4 Ghz band.
And they should have known this in all the communications that we had because I mentioned it to them in our correspondence instead of me finding out here.
Thank you to all that responded.I will closing this thread.
CrimpOn
Nov 26, 2025Guru - Experienced User
whitetiger97 wrote:with a wireless backup up camera in my vehicles.
More than one vehicle equipped with backup camera?
Would this be a Garmin BC40 or BC50 Wireless Backup Camera?
- whitetiger97Nov 26, 2025Aspirant
I have found that the camera transmitter is on channel 11.
I have two systems in different vehicles. I have three GPS units that I have paired and tried in the most prominent vehicle that I need a back up camera in.
It is the BC50 system.
