MAS47
Feb 22, 2026Aspirant
IOS 26.3 Upgrade - Can not connect to Internet but connected to the ORBI WiFi Network
On V7.2.8.2_5.1.18. Frustratated no amount of reverting to factory defaults will alow me to connect to the interent even though I can connect to the WiFi network and do anythign I want to config th...
- Feb 26, 2026
The Roger’s router is an CGM4981RG. Not too helpful looking it up but seems to be a 6/6E device.
I see the 7.2.8.5 FW release, have to load it manually, auto settings say I’m upto date.
yes I’m in Cacada and maybe that’s why the new FW is not showing.
will let you know my results.
Feb 22, 2026Guru - Experienced User
Which model Orbi system do you have?
I've had my Iphone with iOS 26.3 connected to a 850 series before.
Try forgetting the wifi profile then reconnect and besure you set the Protected WiFi setting to Fixed or Disabled while your at home.
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
