MAS47
Feb 22, 2026Aspirant
IOS 26.3 Upgrade - Can not connect to Internet but connected to the ORBI WiFi Network
On V7.2.8.2_5.1.18. Frustratated no amount of reverting to factory defaults will alow me to connect to the interent even though I can connect to the WiFi network and do anythign I want to config th...
- Feb 26, 2026
The Roger’s router is an CGM4981RG. Not too helpful looking it up but seems to be a 6/6E device.
I see the 7.2.8.5 FW release, have to load it manually, auto settings say I’m upto date.
yes I’m in Cacada and maybe that’s why the new FW is not showing.
will let you know my results.
MAS47
Feb 26, 2026Aspirant
Feb 26, 2026Guru - Experienced User
MAS47 wrote:The Roger’s router is an CGM4981RG. Not too helpful looking it up but seems to be a 6/6E device.
Looks like the Rogers variant of the Technicolor CGM4981. So a WiFi 6E gateway.
Try testing the iPhone with the Rogers WiFi - if that fails, try again with the Orbi turned off. Let us know the results.
After that test, try turning the Rogers WiFi off (if you haven't done that already), and see if the Orbi behaves better.
Are the problem iOS devices the only ones that are using 6G WiFi?
