Pad-Rock's avatar
Pad-Rock
iPhone 12 Pro and iPad Pro move around the house and jump between satellites
I have broadly the same issue as the one described.  I have the RBR750 Router plus two satellites - the firmware versions V4.6.9.11(router) & V4.6.5.14 (satellites), although I've had the issue for quite a while and through multiple firmware updates.
Same as the OP, whenever my iPhone 12 Pro and iPad Pro move around the house and jump between satellites / router they looses connection whilst still showing up as being connected to the Wi-Fi in the devices' settings.  My way to get them to work again is to toggle 'Private Wi-Fi Address' on and off to force them to reconnect.  They will eventually reconnect if left for long enough, but it's not exactly seamless.  I've tried having 'Limit IP address Tracking' both on and off on the devices, but that doesn't seem to make any difference.
I've done a bit of Googling and searching through the settings, but can't quite work out what is going wrong  Hoping someone might be able to help and point out a simple setting I've missed!
  • I have broadly the same issue as the one described.  I have the RBR750 Router plus two satellites - the firmware versions V4.6.9.11(router) & V4.6.5.14 (satellites), although I've had the issue for quite a while and through multiple firmware updates.
