liamscor
Jul 07, 2025Luminary
iPhone 15 Plus Connectivity Issues on RBKE963B (Orbi 960 Series)
Hi all, We currently have a guest staying with us who is using an iPhone 15 Plus, and they’re experiencing significant connectivity issues on our Orbi RBKE963B system. The link speed fluctuates w...
Jul 07, 2025Guru - Experienced User
What FW is on the AXE system?
What iOS is on the iphone?
Some have reported that Apple and Orbi may have odd issues with mixed mode WPA settings. Others mentioned setting WPA3 only.
All this seems to be between Apple and NG. Not much we can do here. I just took my 963 off line yesterday after 31 days of solid up time and operation. However I don't have any newer gen Apple phones. 12 Pro Max has been working great.
- liamscorJul 08, 2025Luminary
Hi Furry,
Thanks for your response:
What FW is on the AXE system: 7.2.7.15 - Factory reset and setup from scratch was performed.
What iOS is on the iphone: 18.5
Liam
- FURRYe38Jul 08, 2025Guru - Experienced User
Seems like neew generation devices like Android and Apple are having issues with orbi systems these days. NG is aware and seems to be working on it.
Other issues are IPv6 on this version as well. Not sure if you have that enabled or not or need it. If you use IPv6 then it's recommended to revert FW back to v.21 or v.31 as IPv6 works on those versions. We've made NG aware of this.
Hi Furry,
Thanks for getting back to me, I guess it's just a waiting game then. I currently have IPv6 disabled.
Liam
