brandobot's avatar
Oct 06, 2023
IPhones and iPads constantly lose connection or will connect with self assigned IP address.
I have this same exact issue. IPhones and iPads constantly lose connection or will connect with self assigned IP address. This router is horribly unstable
  • FURRYe38's avatar
    What model Orbi do you have?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    What region are you located?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    • brandobot's avatar
      brandobot
      Guide
      V6.3.7.10_3.3.3
      Rbke963
      MAC randomization is turned off
      2 RBS
      House is 2400 sq ft and RBS are spaced more than 30 ft away and have some obstruction (walls, closet doors, etc..)
      located in Northern California
      Using AT&T fiber with bgw210 modem (ATT provided)
      All other devices work flawlessly except for three iPhones and an iPad in my family. (Iphone 15 pro, iphone 13, and ipad pro
      • FURRYe38's avatar
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Try option #2 first...
        Ok for that size of home, you only need the RBR and 1 RBS. Two RBS maybe causing those devices to ping pong around and not connect properly and fail to lock on. I have a 5000sq ft home and get away with one RBS. When I do have both connected, I turn down the power on the RBR to 25%. Haven't seen any issues with my Apple devices.
        Turn OFF both RBS first and see if the Apple devices connect to just the RBR alone. Then try just one RBS out at 30 feet from the RBR. I'd turn down the power on your RBR to 50% and then test again.
