FirstCup
Nov 06, 2025Guide
IPV6 no connection RBR 850
I called my ISP and they confirmed I have an ipv6 connection available from them on a fiberoptic connection to my Orbi RBR 850 which will not transmit ipv6 to my network and when I run an online ipv6...
Nov 06, 2025Guru - Experienced User
There is a known issue with v.15 FW and IPv6 failing to work.
If you need IPv6, then you'll need to downgrade the RBS first then RBR lastly to v.21 FW as that version was last known working for IPv6.
Once you have the system downgraded, please factory reset the system and setup from scratch.
Who is your ISP?
What brand and model# is the ISP modem/ONT?
