FirstCup
Nov 06, 2025Guide
IPV6 no connection RBR 850
I called my ISP and they confirmed I have an ipv6 connection available from them on a fiberoptic connection to my Orbi RBR 850 which will not transmit ipv6 to my network and when I run an online ipv6...
Nov 19, 2025Guru - Experienced User
Something to try and see if new FW has IPv6 working if your interested:
NOTICE: New - RBR850 / RBS850 Firmware Version 7.2.8.2 Released | NETGEAR Communities
FirstCup wrote:I called my ISP and they confirmed I have an ipv6 connection available from them on a fiberoptic connection to my Orbi RBR 850 which will not transmit ipv6 to my network and when I run an online ipv6 test it confirms not connected.
RBR 850 firmware v7.2.7.15, I just read on the netgear site this firmware is a problem for ipv6 and to set back the firmware to a previous version. I have checked my router settings many times in the advance ipv6 settings, currently set to DHCP
any thoughts from anyone who has experienced problems with ipv6 connection issues would be greatly appreciated. Thanks,
KMDonlon
Nov 20, 2025Virtuoso
Not working :(
- KevinLiTNov 21, 2025NETGEAR Moderator
Hello KMDonlon,
Welcome to the NETGEAR Community!
I understand that you are having issues with your IPv6 connection on your RBR850 with firmware 7.2.7.15. This issue can be a result of using an older firmware version. Please try our most recent firmware for your RBR850 FW v7.2.8.2 then factory reset your system.
Please navigate to the download link below to download Firmware v7.2.8.2 for your RBR/RBS850 (Please be sure to update the satellite first):
https://kb.netgear.com/000070385/
For step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comPlease keep us updated on the progress of this issue!
Best,
Kevin
NETGEAR Team
- KMDonlonNov 21, 2025Virtuoso
Yes, FURRYe38 is correct. I have tried v7.2.7.15 & v7.2.8.2. IPv6 drops on both versions.
Worked just fine with no dropping with prior firmware versions. I am currently running V7.2.6.31 with no issue. Also had no issues with several previous versions prior.
Issue began starting with v7.2.7.15. I have exhausted all the mentioned troubleshooting steps in previous threads. Something was introduced or excluded with v7.2.7.15 and
v7.2.8.2 for the dropping to begin.
My ISP is Cox. I am on a fiber connection from a Nokia ONT
- FURRYe38Nov 22, 2025Guru - Experienced User
Just checking, are you using detected ISP IPv6 DNS or custom IPv6 DNS?
How is the RBR configured for IPv6, which mode are you using from the IPv6 drop down menu?
