FirstCup
Nov 06, 2025Guide
IPV6 no connection RBR 850
I called my ISP and they confirmed I have an ipv6 connection available from them on a fiberoptic connection to my Orbi RBR 850 which will not transmit ipv6 to my network and when I run an online ipv6...
CrimpOn
Jan 09, 2026Guru - Experienced User
It would be interesting to see a summary of which Netgear WiFi7 Orbi's (770, 870, 970) are known to support IPv6 (or fail to support IPv6) on each of the major Internet Service Providers.
i.e. Does IPv6 FAIL for the 870 on every ISP? Do 870's work on cable systems (Comcast, Cox, Spectrum), but fail on fiber systems?
KMDonlon
Jan 09, 2026Virtuoso
I'm on Cox fiber, odd part to me is prior versions (before v7.2.7x.) worked flawlessly and has remained broken with the last 2 updates of firmware. Also the time frame seems a bit odd with such a major brand and the length of time for a repair...almost a year now...just strange they have been unable to sort it out.
- KMDonlonJan 10, 2026Virtuoso
Minor correction to my last post. 3 firmware versions, not 2 since IPv6 has failed to stay connected.
Broken using:
v7.2.7.15
v7.2.8.2
v7.2.8.5
