Sameem
Nov 05, 2025Aspirant
Is v7.2.7.15 stable?
Hey guys, I have an Orbi rbr 750 with two rbs750’s spaced out not too far. This has been happening for a while now but depending on the software version it becomes unstable. Constant disconnects ...
liamscor
Nov 09, 2025Luminary
v7.2.7.15 has been rock solid for me on the 960. I did a factory reset and set it up from scratch via the web GUI. The only key things that I know of to change that are important are that IPv6 is disabled and then set one of the non-overlapping channels on the 2.4GHz band, which varies depending on your region. See below:
https://kb.netgear.com/1027/Selecting-wireless-channels
