ClaudioGold
May 16, 2026Aspirant
Issue with RBR750 with app
Hi: I was using the product with two satellites for couple of years without any issue. Yesterday detect a problem with some connection and start looking for the issue, so detect in the app that th...
May 16, 2026Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What firmware version is on the system?
What mobile platform are you using?
What version of the Orbi app are you using?
Happens on a different mobile device?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
