ClaudioGold
May 16, 2026Aspirant
Issue with RBR750 with app
Hi: I was using the product with two satellites for couple of years without any issue. Yesterday detect a problem with some connection and start looking for the issue, so detect in the app that th...
ClaudioGold
May 17, 2026Aspirant
I coudn´t login into web interface. Connection is refused.
FURRYe38 the issue is I have reinstalled the app so need to configure a new one. When follow the steps in the app, the app can´t find the Orbi network (even I am connected in the phone and other peripherals.).
Regarding the firmware is the prior to the latest one. Now since can´t get into app, can´t see the version to mention.
My mobile platform is iOS
The latest, since I reinstalled
I didn´t check from other phone, but all the ones I could check are iOS.
So wrapping up... the issue now is I can´t access to the network from the app, in order to be able to manage it.
Thanks for your help and comments.
Claudio
- FURRYe38May 17, 2026Guru - Experienced User
What firmware version number is on the system?
What version of the Orbi app are you using?
You'll need to do a factory reset and setup from scratch. Power OFF the ISP modem for 1 minute then back ON. Press the reset button in back of each RBS for 15 seconds then release, then do same for the RBR. Give 5 minutes then walk thru the RBRs set up wizard using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
I might bring the RBS to same room as RBR so you can watch the front LED indications.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Or you can try connecting an mobile device and use Orbi app to set up a new system using the app. I prefer the PC method.
