frekin
Jun 02, 2025Aspirant
Issues with an RBR850 (router mode) and one single RBS850 connected wirelessly
I have remarkably similar issues with an RBR850 (router mode) and one single RBS850 connected wirelessly. Hitron CODA56 DOCSIS 3.1 cable modem on ostensibly gigabit cable service. Cable modem ne...
- Jun 30, 2025
Final update:
I scheduled 2 additional visits by cable company technicians to check my street's cable hub and my home's drop. Finally, I got a supervisor-level technician who correctly identified a problem with the line extending from the drop into my house. He replaced the line after the drop, and I replaced additional lines within the attic; the RBR850 has now functioned without any issues whatsoever for over a week.
I now get the rated transfer rates and consistently low pings in every device I've tested via wifi (close to RBR) and ethernet. This was clearly an issue with the cable lines. Kudos to the gurus in this forum for calling it correctly from the beginning.
Jun 03, 2025Guru - Experienced User
Who is your ISP your connected with?
Is IPv6 enabled on the RBR?
Be sure to run speed tests with a wired PC and Ooklas installable speed test app for best speed test results.
Does this happen with the RBS turned OFF?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Has a factory reset and setup from scratch on the Orbi system been performed since last FW update?
Mine ran for 30 plus days with good operation on this version of FW.
