BlueMoon1801
Aug 30, 2021Follower
Issues with throttling internet speed.
Model:
AX4200 WiFi Satellite (RBS750)
I'm plugged in via ethernet with my gaming desktop. Just bought this 5 days ago and was working good the first day. Been having problems with it since then with it throttling my speed. When I restart it while it is pulsing white my speeds are back to normal. Then after it is all done restarting and returns to its amber light my speed goes back down and is inconsistent. Randomly every 30 minutes or so it will pulse white and then I will get my speed back for about 1 minute to 30 seconds then will go back to the amber light and my speed will then be throttled.
Link to the pulsing white speed test:
https://www.speedtest.net/result/11957489775
Link to the amber light speed test:
https://www.speedtest.net/result/11957494883
Any help will be appreciated, thank you :)
MIght get better results posting in the Orbi AX forum for the RBK750
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
I'd also include what gateway you're using
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Try disabling the following and see:
Armor, AX mode on the RBR and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
