sunny4455
Dec 11, 2024Aspirant
I've RBR850 with RBS850 Satellite. Trying to add a additional RBS850 but it wouldn't sync
I've RBR850 with RBS850 Satellite. Trying to add an additional RBS850 satellite but it wouldn't sync. I see blue light, the RBS Satellite connects and then goes offline. Please advise.
Make sure FW on the incoming RBS is same as what is loaded on the current system.
- sunny4455Aspirant
Thanks. I was suspecting that FW is the issue however didn't know how to upload that. Finally I was able to update the firmware on the additional RBS850 and now everything seems to be working.
Once again thank you very much. Appreciated!- FURRYe38Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
