BiGMERF
Sep 11, 2020Apprentice
Just got home and ughh slow wifi.. RBK852
Well i went from Mesh system to mesh system trying to find the perfect fit.. Mainly trying to avoid the price tag associated with the Orbi ax6000.. Most recently tried the Arris AX11000.. returned that one this morning and came home with the Orbi.. Saw videos on youtube of reviewers pulling in 7-8-900 over wifi.. I set everything up expecting the same thing... speed test via the app using the orbi wired shows 900/940.. but standing right next to the node using my iphone 11, wifi comes in at measly 120/300.. whats the deal?
1 Reply
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Install WiFiSweetSpots on your phone. Then have the phone connect to the RBR. What is the connect speed rate seen on the app? This is just testing the connection rate, not a bandwidth rate.
https://www.youtube.com/watch?v=unc36O66Ef0&feature=youtu.be&t=1062
