liamscor
Jan 24, 2026Luminary
"Korea" in "Advanced Wireless Settings" page "RBKE963B"
Hello, As I mentioned in another thread, I am also seeing "Korea" listed on the Advanced Wireless Settings page, even though my other region settings are correct. I am running firmware "7.2.7...
Jan 24, 2026Guru - Experienced User
Is this the first time seeing this after updating FW?
Was this seen on prior versions?
Seen on newest FW version? I'll check my 960 series and see as well.
What region are you located?
What ISP are you connected with?
- FURRYe38Jan 24, 2026Guru - Experienced User
Checked my 960, regions is for USA which is were I'm at. RBR960 not connected to any ISP services. Sparklight
Check my 850 series as well, was on prior FW version v.2. Showed USA region correctly.
Manually updated FW on the entire system to v.5 FW, RBR not connected to any ISP.
Showed USA correctly after FW update. Put RBR850 online with ISP and still region is correct.Use a DIRECT Link from your cloud storage service then use the camera icon on the forum post tool bar then select from URL option, copy and paste in the DIRECT LINK url. Should appear like mine does.
- liamscorJan 24, 2026Luminary
Hopefully this will work this time.
Was this seen on prior versions?Seen on newest FW version? I'll check my 960 series and see as well.
