liamscor
Jan 24, 2026Luminary
"Korea" in "Advanced Wireless Settings" page "RBKE963B"
Hello, As I mentioned in another thread, I am also seeing "Korea" listed on the Advanced Wireless Settings page, even though my other region settings are correct. I am running firmware "7.2.7...
Jan 24, 2026Guru - Experienced User
Checked my 960, regions is for USA which is were I'm at. RBR960 not connected to any ISP services. Sparklight
Check my 850 series as well, was on prior FW version v.2. Showed USA region correctly.
Manually updated FW on the entire system to v.5 FW, RBR not connected to any ISP.
Showed USA correctly after FW update. Put RBR850 online with ISP and still region is correct.
Use a DIRECT Link from your cloud storage service then use the camera icon on the forum post tool bar then select from URL option, copy and paste in the DIRECT LINK url. Should appear like mine does.
liamscor
Hopefully this will work this time.
- FURRYe38Jan 24, 2026Guru - Experienced User
Is this the first time seeing this after updating FW?
Was this seen on prior versions?Seen on newest FW version? I'll check my 960 series and see as well.
What region are you located?
What ISP are you connected with?- liamscorJan 25, 2026Luminary
Hi FURRYe38
Thanks for your response.
Is this the first time seeing this after updating FW? I think so but can't be sure.
Was this seen on prior versions? From memory I don't believe it was, but again I can't be sure.Seen on newest FW version? Seen on firmware "7.2.7.15", I haven't yet tried the latest firmware.
What region are you located? UK
What ISP are you connected with? EE- liamscorJan 30, 2026Luminary
I just updated to firmware "V7.2.8.5", and then factory reset and setup from scatch and its still showing "Korea".
