Rulother's avatar
Rulother
Last known Orbi750 firmware with telnet functionality?
So I'm needing to make my guest network a 5ghz only network and apparently I need to telnet into the orbi system in order to deactivate the 2.4ghz for it, however my firmware does not even list this option under debug.htm and I'm told that is due to the a firmware upgrade that removed the "enable telnet" option. I'm looking for the last known firmware that had this option so I could enable it and then go through and disable 2.4ghz, and then upgrade the firmware back to the current version. Any recommendations? Would love it if this was just an option in the admin panel like it is for every other network router out there...
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Any changes you make in telnet will not persist thru a FW update nor a reboot.
    Thank you
    • Rulother's avatar
      Rulother
      Wait are you saying if I disabled 2.4ghz for the guest network in telnet, then after a reboot it will be re-enabled?
      • FURRYe38's avatar
        Correct. Why are you trying to set 5Ghz only for Guest Network?
