Rodjac
Feb 10, 2025Aspirant
Latest firmware for RBR860
Hi, I have 2 RBR860 units at different locations, both with the firmware version V7.18.6.13_5.18.4 yet neither will allow an auto update and I have found no history of this version of firmware either.
Could someone tell me if the firmware version v7.2.6.31 is the latest as 18 is higher than 2 (in my opinion) but with no record of it I am keen to manually load the current firmware.
Is there any hooks I should be aware of also?
Thanks
Can you confirm v7.18.6.13?
I dont see that version listed on NGs web page...
Most current version is v.31
Most stable and recommended version is v.21
Is this a retail system or from and ISP maybe?
- RodjacAspirant
I agree. That is exactly what I have uncovered hence my confusion.
- RodjacAspirant
Hi, thanks for the reply.
They are definately that version, screen shot below
I am unsure if they are from ISP but unlikely given cost as I bought them both second hand from 2 different sources
THen they would be even more recent FW versions and probably from some ISP that can be seen on some that get HW from NG and ISP develop there own FW. Something not supported by NG after the fact.
