ABuYang
Oct 27, 2025Tutor
LINE App Cannot Send or Receive Messages When Connected to RBR750 WiFi
Hello All, Since two days ago, mobile devices (iPhone 16 and older Android) connected to our RBR750 WiFi cannot send or receive messages on LINE, and LINE VOOM videos fail to play. Switching to mobi...
- Oct 28, 2025
ABuYang wrote:
The ISP modem is connected to two devices:
MOD
RBR750What is MOD???
ABuYang wrote:
The RBR750 obtains its IP address directly from the ISP modem,
so this setup should match the Option 2 configuration you described.Maybe not. Is the RBR750 getting a private IP address from the ISP? The private address ranges are
- 10.0.0.0 to 10.255.255.255
- 172.16.0.0 to 172.31.255.255
- 192.168.0.0 to 192.168.255.255.
Have you tried connecting a PC to one of the gateway (modem) ethernet ports, and see if you can access LINE w/o using the RBR750?
CrimpOn
Oct 27, 2025Guru - Experienced User
Are you in Japan?
ABuYang
Oct 27, 2025Tutor
Hi,
Thank you for your reply.
I’m located in Taiwan, which is geographically close to Japan,
but I don’t think this issue is related to any license problem.
The main issue is that LINE messages cannot be sent or received properly, which is the app’s core and essential function.
Testing with LINE VOOM is just another way to verify whether the device can successfully connect to the LINE servers, not only for text communication but also for video and media transmission.
So far, I haven’t seen any error messages related to licensing.
It behaves more like a situation where the app cannot connect to the internet, as no content or interface elements are loaded.
Thank you again for the information you provided.
If there are any other possible solutions or settings to try, please feel free to share them — I’m happy to test further.
