Streak2
May 01, 2026Master
Losing internet connection after reboot
I am experiencing a strange problem. I have been an Orbi user and for many years. My setup is an AT&T BGW320 gateway and my RBR760 with 2 RBS760 satellites connected to it in router mode. No bridg...
May 12, 2026Guru - Experienced User
Any progress on this?
Any feedback to the questions presented?
Streak2 wrote:I am experiencing a strange problem.
No bridging or IP passthrough I just have the Orbi running on it's own network with it's own IP range 10.0.0 with my BGW320 on 192.168.1
Just recently if I unplug and replug the Ethernet cable or reboot the 760 it loses internet connection.
I can access the web gui interface but it says no internet connection.
If I reset and reinstall the 760 then all works fine again and it will continue to do so until the next reboot.
Over the years I have rebooted, reset, unplugged and re-plugged ethernet cables and never experienced this issue.
What could be causing this all of a sudden?
