scleary81
Jun 09, 2025Aspirant
Loss of connection between satellites
I am currently running the Orbi wifi 6/6E system, with a router unit and satellite. I have noticed a consistent problem of maintaining the paired connection between devices, based on proximity to sat...
Jun 09, 2025Guru - Experienced User
What model Orbi system do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
