vikkiban
Nov 08, 2022Aspirant
Mac getting 169 IP for MacOS with RBR750
This problem starting happening last week with no apparent change. My mac is getting 169 ip instead of 192 when it connects to Orbi satellite. All other devices are working ok. Only happens with mac....
Nov 08, 2022Guru - Experienced User
So you have the 9 series Orbi system?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
vikkiban wrote:
This problem starting happening last week with no apparent change. My mac is getting 169 ip instead of 192 when it connects to Orbi satellite. All other devices are working ok. Only happens with mac. Tried to reboot orbi and satellites - noting seems to help. sometimes turning off wifi on mac or doing DHCP lease renew fixes it, but then it again connects to 169 (local) after few mins. Any help or pointers will be highly appreciated. No change in modem, router or mac. all have been working fine for months before this problem popped up
- vikkibanNov 09, 2022Aspirant
Thanks. Details below:
Its Orbi RBR750
1. Firmware:V4.6.9.11_2.3.5
2. Netgear model CM1100
3. Cat6 used between modem and router.
The issue is only one one mac when connected to orbi network. All other devices get connected ok. On the effected mac, it works fine when connecting to a hotspot.
