vikkiban
Nov 08, 2022Aspirant
Mac getting 169 IP for MacOS with RBR750
This problem starting happening last week with no apparent change. My mac is getting 169 ip instead of 192 when it connects to Orbi satellite. All other devices are working ok. Only happens with mac....
vikkiban
Nov 09, 2022Aspirant
Thanks for helping. Yes, something must have changed. I am trying to see if mac address randomization is happening.
Nov 09, 2022Guru - Experienced User
That or IP address Limiting as well.
I have a Mac Book Pro 2018 and have Both Monterey and Ventura loaded. Haven't seen any issues yet.
You might forget the SSID profile from the Mac and then re-connect and let the system re-configure things.
- vikkibanNov 09, 2022Aspirant
So, mac address randomization is not happening. Checked that and the hardware mac address remains the same. Cross checked under orbilogin.net = under connected devices and it is showed the same hardware mac address for orbi.
2. switched off ip limiting address - no effect. Also tried forgetting network and deleting the concerned plist. but issue remains
Under connected devices (in orbilogin.net), the mac is allocated a valid 192 ip address. Also, it shows mac is connected to a satellite and shows 5GHz connection. Tried to remove the satellite, but thats not the issue. Any other thoughts? Was checking some other threads, and one of them had a suggestion to change CTS setting - I don't know much about what that setting does. Worth trying?
- CrimpOnNov 09, 2022Guru - Experienced User
If the Orbi thinks that Mac is connected, can you use a different device to ping that IP?
its timing out.. i tried to ping ip for other devices and those are ok. However, i have two other family member's laptops connected (and working fine). i pinged the ip for those laptops as shown in orbi connected devices, and they are also timing out. But those devices have connectivity. Also, the ip for one of the connected laptop as shown in orbi connected devices is actually diff when i go to the wifi details for that laptop.
