FelipeBarbosa
Mar 30, 2026Aspirant
MacBook only connecting to 2.4GHz
Hello all, I have a RBR850 router and two RBS850 satellites. The second satellite was added a few weeks ago, and since then (but it might be unrelated) my macbook stopped connecting to the 5GHz WIFI ...
FelipeBarbosa
What model# year Mac Book do you have? -- Apple M4 Max
What OSX version is loaded on the laptop? -- macOS Tahoe 26.3.1
Be sure to disable any MAC Address randomizers on phones and pads while at home: -- Did it, no difference
What Firmware version is currently loaded? -- V 7.2.8.2
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? -- Sagemcom F3896LG-ZG
Is IPv6 enabled on the RBR? No
What is the size of your home? Sq Ft? -- 1496,18 (138 sq meter)
What is the distance between the router 📡 and satellite(s)🛰️? -- more or less 20 foot
Does this happen with the RBS turned OFF? -- never tried
What channel configurations are currently set on the router? -- it was auto for 2.4 GHz and 44 for 5GHz, then I played around setting values for the channels but made no difference.
Mar 30, 2026Guru - Experienced User
FelipeBarbosa wrote:Be sure to disable any MAC Address randomizers on phones and pads while at home: -- Did it, no difference
What Firmware version is currently loaded? -- V 7.2.8.2Might update FW to v.5:
New - Orbi RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released | NETGEAR Communities
If you do, update the RBS first then RBR lastly.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? -- Sagemcom F3896LG-ZGYour ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-pointand https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
For that size of home, the RBR would be enough. Maybe one RBS deployed at 30 feet or more.
Thats too close. 30 feet distance is starting distance between the RBR and each RBS.Turn OFF the RBS and test. Then try with just 1 RBS out at 30 feet.
What channel configurations are currently set on the router? -- it was auto for 2.4 GHz and 44 for 5GHz, then I played around setting values for the channels but made no difference.Try channel 1 and 40 or 11 and 48
