checkyourmirror
Dec 31, 2025Aspirant
Main 960 in AP Mode doesn't show Satellites in Attached Devices over enet
I've been using my 960 in Router mode with two satellites backhauled over ethernet, and everything was working great. I could see the satellites in the attached devices. I switched over to using the ...
Dec 31, 2025Guru - Experienced User
How are the RBS ethernet connected to the RBR? Any LAN switch in between the RBR and RBS or is RBS ethernet connected to the host router?
RBS require being connected directly behind the RBR, Even if a LAN switch is in the mix, the connection path needs to be behind the RBR, router or AP mode as seen here: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System📡 ‌‌🛰️
